3 members (tclederman, Bill Hanlon, 1 invisible), 197 guests, and 3 robots.
Topics128,106
Posts1,056,213
Members48,436
#88444 03/16/2002 6:16 PM
I have either a brake light or reverse light staying on. At the time of this post just started tracing. Now go head and call me a dumb A$$ but is there a switch that can go out in the shift mechanism? What tells the brake light to come on? I know there is a switch on my other autos but can not find one on this truck, for the brakes that is. What tells the reverse light to come on? I feel really toopid! Any help will be appreciated.
#88445 03/16/2002 8:56 PM
fatboy58, I will assume you have a 58 apache. If you will look on the firewall right under the steering colunm, you will see a switch.
Tommy
Tommy
59 apache 1/2t
261 short stepside
#88446 03/16/2002 9:33 PM
Back-up lights are switched on(some applications) by a switch on the top of the tranny.The brake switch should be in the engine compartment on the fire-wall where the pedals come throught hte floor.
#88447 03/17/2002 12:23 AM
well thanks alot guys I appreciate it. I saw somewhere on an earlier post something about if all else fails read the directions ie manual. The reason I could not find the switch even after looking at the manual is because it was not there. Yes it fell off. I have it fixed now. Again thanks. What a helpful crew. I just wish I could help someone out as I have been helped so many times.
