| | | Forums66 Topics128,034 Posts1,055,440 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#88441 10/04/2002 5:14 PM | Joined: Nov 2001 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 111 | Does anyone know the original location of the external resistor that is inline on wire to ignition coil? It is on a 1951 Chevy pickup. It mounts on the firewall but where is the particular spot that the factory located it? thanks for the info mh
54 Chevy 5 window - 46 Chevy 1/2 ton
#88442 10/04/2002 11:42 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | There was none in 51. You only need one if you converted to 12 volts. Located it wherever is convenient.
#88443 10/07/2002 1:22 AM | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | If you have a heater, there may be some long 1/4 studs that project from the firewall. I used some washers with rubber washers too and a locknut to mount it securely. | | |
