0 members (), 68 guests, and 8 robots.
Topics128,021
Posts1,055,355
Members48,420
#88441 10/04/2002 5:14 PM
Does anyone know the original location of the
external resistor that is inline on wire to ignition coil? It is on a 1951 Chevy pickup. It mounts on the firewall but where is the particular spot that the factory located it? thanks for the info mh
54 Chevy 5 window - 46 Chevy 1/2 ton
There was none in 51. You only need one if you converted to 12 volts. Located it wherever is convenient.
Paint & Body Shop moderator
If you have a heater, there may be some long 1/4 studs that project from the firewall. I used some washers with rubber washers too and a locknut to mount it securely.
