4 members (dt235sd, Rick Brown, Jon G, 2-Ton), 170 guests, and 2 robots.
Topics128,108
Posts1,056,238
Members48,437
Hello,
Quick question: I am in the process of dismanteling my '46 and looked at how the front fenders are attched. I don't know if this is original or not, but it looks like the upper half of the front fenders are somehow how attached with "screws/rivets" that have a flat(smooth) head towards the engine and are flush on the other side. What are these and what is the safest way to remove them without causing damage to the sheet metal?
Andy
I drilled mine out, worked just fine. Are you talking about the ones that connect the inner fender to the outer or the ones on the fender extension, either way I drilled them all. I had to take the fender extensions off because I used fiberglass fenders.
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
Ditto on the above Andy! How are you making out with that Upstate NY truck?
Dan
Ok. Thanks. What did you guys use to fasten them back together at the end?
Dan - I am taking it completely apart and will try do it right from the beginning smile sloooowly coming along...
Andy, I drilled mine out as well and went back with stainless machine screws.
