| | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 103 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 103 | I am really a novice on these trucks. I think I read enough to answer this question. Will a V8 small block fit in a COE where the 6cyl is? The frame rails look very tight. I know folks have put them mid ship. I want to retain the orig wheels and look but upgrade the engine, tranny, and most likely the rear axle. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 51chris, welcome, I think that swap might be doable, but you may have issues with the floor. I would do some measureing, the steering box is right up at the front of the frame so exhaust shouldn't be an issue, but the height of the carb relative to the floor might be, good luck, and please keep us informed of what you find. | | | | | Joined: Feb 2010 Posts: 476 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 476 | Chris: It is very tight,but another 235 C.I. all the way to and including 1962 will bolt in with some minor modifications and a shortened water pump you can buy out of any truck parts book. I bolted my 47 updraft intake,exhaust manifold, bell housing ,flywheel, and valve cover on a 62 235 C.I. It has over twice the oil pressure and insert bearings. | | | | | Joined: Sep 2012 Posts: 103 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 103 | Thanks much chris, do you think a non carbed v8 will fit in the coe? otherwise I will go the 6 cyl route. | | | | | Joined: Feb 2010 Posts: 476 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 476 | If you want a V8 your best bet would probably be to set the cab on a newer chasis,engine and drive line.I've seen COE cabs on modern rollback wreckers. But then your far from original, it all depends what your after. | | | | | Joined: Jan 2010 Posts: 37 New Guy | | New Guy Joined: Jan 2010 Posts: 37 | I've seen this conversion a couple times on stock chassis, including one on ebay recently. Appears to have been done without floor modifications.
If anyone has pics that would be great. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I have seen a V-8 in an AD COE, since the V-8 is not as tallas a 6, it fit OK, even w/ air cleaner. However, a 261, 292, or GMC 302 will give increased performance w/ a stock appearing 6 cyl engine.
