7 members (jay d, Bill Hanlon, RaNfLaS, GMCJammer51, DadsFirstPickup, Tyler Watts, Steelonsteel), 94 guests, and 3 robots.
Topics128,048
Posts1,055,663
#8835 08/05/2003 3:36 AM
Junior Member
Junior Member
Hello, once again I need some help. My steering was really bad, I followed the manual and did step by step checks. King Pins good, drag link ok, need to replace tie rod ends (next project)and finally got to the steering box. I decided to flush the box and put in new oil (Napa 80-120)before setting the two adjustments. Made adjustments with wifes help. Really happy with results. Now the problem (s); I have small oil leak through the threads on thrust adjustment. I did not put any type of sealer on threads, what should I use? Next, oil seal on pitman shaft leaks really bad (started after adding new oil). Since I plan some day to install power steering I don't really want to pull the steer box right now. Can I put a different type of lube in to reduce the leakage? Once again, thanks for any idea's. Roy
#8836 08/05/2003 4:34 AM
I would suggest draining the gear oil from the steering box. Steering gears used a special type of grease that was thicker than even 85W-140. I am not sure but I do not think GM makes it anymore. We had a big discussion on this topic a few months ago, I would suggest you search this site for 'steering box'. I will use John Deere Corn Head grease in my steering box when I go through it, as it is nearly the same consistancy as steering gear grease.
Remember 9-11-01--God Bless the USA
JUSTICE, not REVENGE, will prevail
1951 Chevy 1/2-ton Pickup truck
#8837 08/05/2003 5:21 AM
Junior Member
Junior Member
Restoration Supply Company has the steering box oil you need. It is 1200W, and they say it "....will not run out of your steering box or track like grease.". The part no. is LUB009 (500 ml bottle for $7.50). Their web site is at www.restorationstuff.com .
#8838 08/05/2003 8:02 AM
A cheaper alternative, available at NAPA.
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
#8839 08/06/2003 6:01 AM
Junior Member
Junior Member
Hello, many thanks for the quick replies, I will pull the thrust end plate and drain the box and refill with the recommend lube. I will let you all know how it works. Roy
