0 members (), 128 guests, and 2 robots.
Topics128,127
Posts1,056,680
Members48,452
1961 GMC 1000 with v6
Does anybody know what was available for stock differential gearing that year?
Thanks a bunch!!
Click the link to see my truck.
http://smu.gs/OuBwfv
Found the info I was looking for....thanks guys!!
Three ratios were available through those years:
•4.11 with an overdrive transmission
• 3.90 with a standard transmission
•3.38 with an automatic transmission.
Mike,
If you have a DANA 44 pumpkin, you can drop down to a 3.23 gear set from Presion Gear $250.00 with all the barings. like I did.
http://rides.webshots.com/album/570438270cjSEvE
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
Thanks!!
My info show it came with 3.90 gearing to begin with. Can you confirm that?
Yes, I had the same ratio I bought a carrier gear, a pinion and the associated barings. While you have everyhing apart, swab out the axle tubes with a laquer thinner and some old rags, blow dry. You can also use a copper scrubber pads on a long stick (broom or mop handle for some good scrubbing action. Staple the pad to the stick gong back and forth. Replace the axle barings. You'll hate yourself for not doing it while you cleaning eveything up.
I've got a set of 3.07 gears out of a dana 44 from '60 2wd GMC. Seems that was the 'economy' gearing with the 305 & 1 bbl Holley.
BC
1960 C60 pasture art
I found this online someplace, not sure if it is 100% accurate.
I think that is true for the corprate / Eaton axle used in Chevy but not sure about GMC / Spicer / Dana axles.
BC
Any way for me to know on the GMC? Any stampings or numbers?
Would have had a tag on one of the cover bolts, if that's gone, take the cover off, Should be stamped on the ring gear (or count teeth on ring & pinion).
BC
Originally Posted by Modelman
Mike,
Good stuff. Thanks for sharing.
Thanks!!
