3 members (Bill Hanlon, FishinToms53, tesa), 110 guests, and 2 robots.
Topics128,087
Posts1,056,000
Members48,430
#700231 12/02/2010 4:09 PM
Im getting ready to re upholster the bench seat in my 50 chevy. The seat frame i have uses the cable/pulley design to adjust it though my cable had snapped so im sure what how the cable configuration works, does anyone have a snap shot or layout of this, thanks
1950 Chevy 3800
4-53T Detroit Diesel conversion
More pictures in Photobucket
Follow this link thru a couple of pages. It should help you.
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0115.htm
Drew
cool thanks
1950 Chevy 3800
Here's what I have so far, the cable travels the same direction on both sides, but the double pulleys don't move at all. Are they supposed to be independant?
One pulley has to turn one way while the other should go the other, or else eventually it'll fray up the cable or wear out the pulley. Is there something I'm not seeing here?
http://i131.photobucket.com/albums/p290/diseasel/IMG_20101205_164952.jpg
1950 Chevy 3800
The pulleys should move. Mine got hung up from too much paint.I freed them by rotating by hand and applying a little white grease on their center pin. Also, did you cross the cable once as it ran through the seat frame? And adjust it for tension?
Drew
Yes i did cross the cable so that the adjusters move in unison, but the double pulleys look as though theyre one piece, I tried separating them with a chisel to see if they would separate, ill have to try again tonight
1950 Chevy 3800
Hi, I am new to this forum and I am struggling with this very same problem. The link to the shop manual was very good and will be very useful with other items however there is no diagram of the cable layout for the seat adjuster.
Can anyone help with a diagram or picture of how the cable is run.
Doug
I have a few individual pictures of my seat frame in this folder
...link...
unfortunately the pics are not that good but take a look. I didn't need to disassemble the seat frame cable system.
good luck
Thanks that will help somewhat. That's 100% more information than I had a few minutes ago. Thanks for the quick response.
Doug
Moderated by  ndkid275, Phak1
