| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 123 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 123 | Im getting ready to re upholster the bench seat in my 50 chevy. The seat frame i have uses the cable/pulley design to adjust it though my cable had snapped so im sure what how the cable configuration works, does anyone have a snap shot or layout of this, thanks | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 |
Drew
| | | | | Joined: Nov 2010 Posts: 123 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 123 | | | | | | Joined: Nov 2010 Posts: 123 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 123 | Here's what I have so far, the cable travels the same direction on both sides, but the double pulleys don't move at all. Are they supposed to be independant? One pulley has to turn one way while the other should go the other, or else eventually it'll fray up the cable or wear out the pulley. Is there something I'm not seeing here? http://i131.photobucket.com/albums/p290/diseasel/IMG_20101205_164952.jpg | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | The pulleys should move. Mine got hung up from too much paint.I freed them by rotating by hand and applying a little white grease on their center pin. Also, did you cross the cable once as it ran through the seat frame? And adjust it for tension?
Drew
| | | | | Joined: Nov 2010 Posts: 123 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 123 | Yes i did cross the cable so that the adjusters move in unison, but the double pulleys look as though theyre one piece, I tried separating them with a chisel to see if they would separate, ill have to try again tonight
| | | | | Joined: Sep 2012 Posts: 2 New Guy | | New Guy Joined: Sep 2012 Posts: 2 | Hi, I am new to this forum and I am struggling with this very same problem. The link to the shop manual was very good and will be very useful with other items however there is no diagram of the cable layout for the seat adjuster.
Can anyone help with a diagram or picture of how the cable is run.
Thanks Doug | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I have a few individual pictures of my seat frame in this folder ...link... unfortunately the pics are not that good but take a look. I didn't need to disassemble the seat frame cable system. good luck | | | | | Joined: Sep 2012 Posts: 2 New Guy | | New Guy Joined: Sep 2012 Posts: 2 | Thanks that will help somewhat. That's 100% more information than I had a few minutes ago. Thanks for the quick response.
Doug | | |
