2 members (GMCJammer51, 51 3804), 154 guests, and 3 robots.
Topics128,271
Posts1,058,314
Members48,485
#880702 09/06/2012 8:02 PM
I have a 1948 1 ton chev panel with a 235 engine from 1958-1962. It also has a 457 rear end. I put on a tac to see what rpms I am running. At 45mph I turn 1400 rpms-at 50 mph I turn 1800 and at 55mph 2000 rpms. I still have some left but I think I am close to top end. Does this sound right and at what speed or rpms should I run this engine.
first48 #880705 09/06/2012 8:14 PM
4.57:1 ?
2000 rpm at 50 mph seems pretty low rpm?
What type of tach were you using? Does it have a switch to set it for 4/6/8 cylinders?
I think that 2500 rpm +/- 200 rpm is a nice zone.
tclederman #880731 09/06/2012 10:29 PM
Something's weird. That combination of axle ratio and rpm would require 55" tall tires. A more common tall truck tire of 31" should give about 2500 RPM @ 50 MPH. (assuming you don'y have an OD transmission)
regards,
Leon
Leon #880739 09/06/2012 10:50 PM
yes, what they said - at 55 with a 4:57 rear you will be "close to top end", which would be around 3000 rpm - are you sure you have the tach hooked up correctly? and it's not an 8 cyl tach?
Flxible #880786 09/07/2012 6:49 AM
im running the same gear ratio in my 40 with 16" wheels that are 30" tall. im running 2550 rpm @ 50 mph. this has been confirmed many times using my westburg tach, gps and a speed/rpm calculator. with this combination at 60 my engines turning close to 3100 rpm.
51 ashton #880869 09/07/2012 2:21 PM
I suspect your tach is for an 8 cylinder engine. If it's getting 25% fewer impulses then the lower number makes more sense. At least this is my KY windage swag.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
53moneypit #883203 09/17/2012 6:50 AM
what is a KY windage swag?
brokenhead #883206 09/17/2012 7:07 AM
its an eastern thing grin
51 ashton #883357 09/17/2012 8:42 PM
SWAGs or not, it looks like a hit and run post.
We may never know the outcome.
tclederman #883562 09/18/2012 8:54 PM
I thought KY was in the south...I just realized I don't remember any of my 5th grade geography
brokenhead #883574 09/18/2012 9:59 PM
It is east of the Mississippi and south of the Mason-Dixon line.
For those who use Civil War terminology, it was a border state that sought neutrality but gave up on that and petitioned for Union support/control.
tclederman #883602 09/19/2012 7:04 AM
OK thats about where I was thinking, besides consulting a map. What I found out is Kentucky windage is a reference to adusting your aim on the fly for the wind while shooting a rifle, whilst swag is scientific wild @$$ guess. that was actually two jabs...
53moneypit #884727 09/25/2012 8:22 PM
The tac is right now and I turn 2500 rpms at 50 mph with my 4;56 rear end. I have had it up to 57 mph which gets about 2800 rpms and I think close to the top. I am going to a show with my 1948 chev 1 ton panel with a 235 and want to know if 2500 rpms will be fine for a 3 hour trip. Thanks for any help.
first48 #884738 09/25/2012 8:35 PM
I wouldn't expect any problems, I'm sure I've cruised at higher RPMS than that for extended periods with a 235 .... assuming the engine is in reasonably good condition
Flxible #884825 09/26/2012 7:58 AM
You will be fine as long as you have good oiling and it doesn't get hot. The noise that your hearing is the way it used to be, we have all been spoiled with our newer vehicles and all the sound deadening insulation they have in them.
don stocker #885103 09/27/2012 7:59 AM
Amen... and all the super low (numerical) low gear ratio/overdrive drivetrains.
first48 #1167397 05/29/2016 7:38 PM
Does anyone have a 6 cylinder tach that they would be willing to sell?
1958 Chevrolet 3600 NAPCO 4x4 Apache
"Calvin"
first48 #1167405 05/29/2016 8:45 PM
Gas Pumper
Gas Pumper
They are pretty cheap on Ebay. Most of the ones listed have a 4-6-8 cylinder switch on them. I just got one recently and paid about $20.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
first48 #1167675 05/31/2016 10:18 PM
I found a pretty sweet looking Mercury Marine tach for a 6 cyl with a 5k rpm scale on eBay for less than $50 last year (mounting kit cost more than the actual tach). They're out there, just gotta wade through all the other stuff to find them. I ended up searching "6 cylinder tach" after looking at too many V8 tachs that did not have the 4/6/8 switch...
PIC
first48 #1167769 06/01/2016 4:23 PM
If you begin to feel a new roughness or buzz, slow down and take a look under the vehicle for something loose, leaking etc.
Otherwise 2,500 is fine.
