2 members (Gray_Ghost, Chip O),
62
Mod | | | Forums66 Topics128,129 Posts1,056,695 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 45 | I need to get away from my 4:56 gearing. I would like to be able to do 65mph.
Is taller gearing available or will I need to swap rearend with a 1/2 ton unit?
What is available for a 1/2 ton unit with 6 bolt lugs and compatible brakes? | | | | | Joined: Jun 2010 Posts: 301 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 301 | I swapped mine out this summer with a rearend from a 69' F250 with 3.73. The width is almost identical. The spring perches will need to me moved slightly and angled properly to lower the differential shaft to a level or slight down angle. The drive shaft will need to be shortened and a different yoke put on to match the F250's. I am very happy with it and i have a 3/4 ton rearend I can readily buy parts and gear sets for.
1949 Chevy 3600 1975 W-25 Hurst Olds 1970 GMC 1/2 ton Fleetside 2010 Chevy Silverado
| | | | | Joined: Sep 2012 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 45 | How much did it lower your RPM's at 65mph? | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Try this link for an RPM calculator. http://www.ringpinion.com/Calculators/Calc_RPM.aspxI've purchased a GM 14 bolt rearend for use in my 54. A 14 bolt Dually rearend basically has the same Wheel mounting surface width as the oem Eaton. I'm with BZTGUY on having a rearend that has parts readily available. GM started using the 14 bolt in 73 and is still using it and Ford has been using one or other variation of the Dana for probably 50 years. Just something to think about. | | |
