| | | Forums66 Topics128,076 Posts1,055,924 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 11 New Guy | | New Guy Joined: Aug 2012 Posts: 11 | Recently purchased a '63 C10 with 12 bolt posi and 3.73. Only a few very short trips before servicing the rear end. I gave it a good cleaning with Varsol and refilled with Lucas synthetic gear oil (75-90?). I also added GM additive when I first noticed some chatter. I still have a posi chatter. Should I get rid of the Lucas? Any other suggestions? Thanks OldsCool | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | I'd add more GM Posi additive.  I put a 12 bolt posi out of a late 60's Impala in my Model A. The Model A is so light compared to the Impala I had to add twice the amount of GM Posi Lube to keep it from chattering. And yes, it still hooks up both rear tires in sraight line acceleration. Hope that helps. John | | | | | Joined: Feb 2004 Posts: 29,778 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,778 | The chatter is caused by the cone clutches grabbing as the rear end differentiates axle speed in a low-speed turn. Regardless of where you get the posi additive, Ford, Chrysler, or GM, it's all the same stuff. Mix it according to the directions on the bottle, and it should cure your problem. At heavy throttle the axles will lock if any slippage is present, so the additive is just to prevent chatter at low speeds with little if any power applied. Jerry
| | | | | Joined: Aug 2012 Posts: 11 New Guy | | New Guy Joined: Aug 2012 Posts: 11 | Thanks John. I'll give it a try. -OldsCool | | | | | Joined: Aug 2012 Posts: 11 New Guy | | New Guy Joined: Aug 2012 Posts: 11 | Thanks Jerry. That sounds right. Low speed turns is where the chatter occurs. | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | ... Mix it according to the directions on the bottle, and it should cure your problem.... Jerry And if it doesn't cure the chattering, use more additive. In my case the amount specified on the additive bottle wasn't enough. It still chattered badly when cornering. But doubling the amount of additive cured the chattering issue. John | | |
