3 members (tclederman, 66flea, 1955 1 Series), 396 guests, and 4 robots.
Topics128,154
Posts1,057,015
Members48,460
I was driving my truck home from work the other day and blew out a transmission seal. I was thinking this might be a good opportunity to upgrade transmissions since I have to pull this one out. It currently has a three speed automatic. I want to install a 5 or 6 speed automatic. The truck has the original 350.
Is this possible?
What transmission could I use?
Could I get a rebuilt one out of a newer truck?
1949 Chevy 4400 Grainbed
Photobucket pictures
The taxpayers are sending congressmen on expensive trips abroad. It might be worth it except they keep coming back!
Behind every successful rancher is a wife who works in town.
Riding in the Passing Lane
This is a very popular modification. The 88 up to about 92 700R4 is a 4 speed o-drive trans. that works great in these trucks. It is fairly easy. You need to get the correct cable hook up & have the drive shaft shortened. You can get one from a salvage or specialty trans. co. If you are near K.C. there is a rebuilder here in town that sells them over the counter at a reasonable price. If you are interested e-mail me. [email protected]
1972 Chevy c10 Cheyenne Super
I have a transmission i am pulling out of a 1989 chevy 1500. I will have to remove the transfer case and install a new tail housing/shaft since my 70' is a 2wd. Will this work? My 70 is a 3/4ton.
You will probably need to have your driveshaft reworked. You will also need to get a way to deal with the lock up torque converter also.
So I will need a lockup kit? I have heard that I will need to shorten the drive shaft.
