2 members (Hush, Forty9), 90 guests, and 1 robot.
Topics128,050
Posts1,055,643
#882947 09/15/2012 11:14 PM
hey all, i have taken the head off of my 235 engine and have it ready to be cleaned, but my question is will oven cleaner clean the head or is this a bad idea. i have researched this and have had several answers come up, that it will destroy aluminum and plastics, etc. but can i use it to clean a cast iron engine head?
thanks in advance for any info
Indy wink
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
Materman #882957 09/15/2012 11:30 PM
if you are't sure, just use something else. they make spray on degreaser if you want convenience. they sell parts cleaner by the gal out of a pump at a local place here if you want economy. oven cleaner might work ok for baked on chicken grease, but who knows about motor grease. besides it has a powerful stink.
Materman #882969 09/16/2012 12:18 AM
You'll be able to degrease with oven cleaner, but it isn't the greatest. It will probably soften, but not completely remove the paint. It won't remove rust. It will eat aluminum.
Hot tanking is caustic like oven cleaner, but much more effective. Heat is key to the process.
Materman #882970 09/16/2012 12:18 AM
I used "easy off"spray on my aluminum carburetor and had good results , sprayed it on left it overnite then washed it off
rick boyd #882993 09/16/2012 9:49 AM
Even if you do use it, you still need to wash it off, so why just hit the car wash to start with. Hot soapy water does wonders, and for a really good cleaning, presoak the parts in Castrol degreaser or Purple power, both are excellent degreaser around $5 a gallon. Oven cleaner works pretty good for brackets and smaller pieces with caked on dry grease. It will burn your skin and eyes, so be careful scrubbing around on it.
Joe
Materman #883011 09/16/2012 11:18 AM
H Online: Content
Oven cleaner is lye- - - -very caustic and hazardous to skin and eyes. I made my own hot tank cleaner by cutting a 55 gallon drum in half lengthwise, welding the two halves together end to end, and filling it up with water, 4 cans of lye, and half a box of Tide. I built a wood fire under it, and dunked an engine block, cylinder heads, and all the steel sheet metal into it. NO ALUMINUM! It worked great, and the leftover liquid got used to treat a bunch of fire ant nests!
Oven cleaner will work OK on small parts, and probably your cast iron cylinder head, followed by a thorough pressure wash but limit the time it's exposed to aluminum.
jerry, your so mean cry
51 ashton #883210 09/17/2012 7:32 AM
I have used the spray on type of oven cleaner numerous times to clean various antique tractors I was working on. Works great.
Kurt
