5 members (artinva, Opelika Tom, JW51, Gdads51, Otto Skorzeny), 65 guests, and 2 robots.
Topics128,077
Posts1,055,932
Members48,430
#883147 09/16/2012 10:08 PM
i have looked at the pad next to the fuel pump and there is no numbers stamp there, is there a differant place to look? thank you in advanced!
http://s1055.photobucket.com/user/baldybenny/library/
1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
thanks Tim, but i can't go there, it wont let me, is there any other way to see that info? dan
likely the numbers on the pad are missing because they were shaved off when the engine was rebuilt sometime in the past - there is no other place to look
thanks Bill, engine still std and has 24,000 miles on the truck,been in storage for over 48 years.just trying to find out more info on this truck, thanks again, dan
Tims info indicates the number would be on that pad, if it's not there, maybe it's an early dealer/factory service replacement, which would probably not be stamped ... maybe there's some casting date marks on the block as the later engines have
