| | | Forums66 Topics128,012 Posts1,055,320 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 103 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 103 | What engine do I have as Im unsure. The number next to the distributor reads 0830940f55y Its in My 51 chevy coe
Thanks in advance | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | It's a 235 from a '55 Passenger car with automatic, built at Flint.
Bill Burmeister | | | | | Joined: Sep 2012 Posts: 103 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 103 | Sir, Thanks Much, Is this a babbit engine or? Is the horsepower the same as the ones thay put in the trucks? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | All 235 engines from 1954 onwards were high pressure engines (1953 Powerlides were also high pressure engines).
The Powerglide car engines were usually higher hp and had hydraulic lifters (136hp vs 123hp). All truck engines used mechanical lifters.
| | | | | Joined: Sep 2012 Posts: 103 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 103 | Thanks Tim,I now have to get it from blowing white stink smoke. Its not water so i assume the carb has to be adjusted. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | "white stink smoke" sounds like a head gasket.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Sep 2012 Posts: 103 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 103 | Well, thats my next decision. Should I rebuild this non original 1955 passenger car engine or retrofit a modern 6cylinder? or V8 if it will fit. Maybe even a diesel if i can figure out how, what, where who. money, skill etc... Thanks Tim Chris | | |
