5 members (Otto Skorzeny, RLB, TUTS 59, NJC, 1 invisible), 88 guests, and 3 robots.
Topics128,030
Posts1,055,430
Members48,422
#882215 09/12/2012 6:46 PM
This weekend, I'll be separating the frame from the body on a 59 panel. I figure it will be about a month before the body is remounted.
Can I support the body from either the 4 corner or 4 center mounts, or should I use all 8?
Does the answer change if one month becomes 6?
Thanks in advance.
Is rust considered a body style?
this one has been on the old baggage car for years - and I do mean years .... just support it on as many cross sills as you can, if the rear floor is still in you'll have no problems whatever
For my '51, I made a simple dolly out of 4 x 4's. See the link below.
Saw that dolly when I was searching for ideas. Pretty sweet!
I was able to roll the body with dolly up on my car hauler and take it home while I worked on the frame at my shop.
Sir Searchalot
Sir Searchalot
If you don't have a lift. I can give you step by step instruction to do it without a lift or a cherry picker. Just two jacks and 4 jack stands, dolly or no dolly. Is the engine and tranny still there? If you need the info, PM me with your email and I will send pics with info.
I have access to a forklift. Not sure whether to pick it from above or lift it from below. Engine and tranny have been removed.
Need to work out a few details on the stand as well. I have 4 heavy-duty saw horses to get it up so I can access the undercarriage. I need to spread out the horses wide enough to fit the chassis underneath.
Sir Searchalot
Sir Searchalot
sounds perfect.
Originally Posted by red58
interesting...
arturo - put a couple long pallets on the forks to catch the roof ribs, sling some rope thru the front doors back to the mast to keep it from tipping forward, and you could motor across town ..... if you could see where you're going grin I just moved it from the rotten old frame to the replacement seen in the foreground, could as easily be put on a dolly
Leo Offline
Moderator
Moderator
I actually used a big forklift too. Worked slick.
