0 members (), 125 guests, and 2 robots.
Topics128,136
Posts1,056,425
Members48,441
when it comes to gmc old stovebolts you seem to know your stuff ... need help... I blew my gmc 248 1941 from a failed valve keeper. intake valve dropped and you know the story from there,,,.. got all the new parts and machine work done and , I was going to put it together this weekend. and needed to know once and for all the valve lash.. so looking at my camshaft # 2136000 on line found in a army book its .012 & .016 .. and was reading where the oil shield had to be .040 or it might hit the valve spring retainer and drop a valve... so I looked under my No,1 cyl intake valve oil shield and yup,,, I can see where its been rubbing,,, .. it makes sense that if the oil shield hitting the valve spring retainer . the older octagon type . its taking pressure off the valve and making the keeper lose.... the army manual talks about putting new keepers and the thinker round valve spring cap/ retainer. on the intake valves,,, I have a few manual pages and pics that explains this and shows in the diagram really well... I can email you them if you don't know what I mean... I can get these round type... all 12 of mine have those octagon type.. I think just the intakes would need to be switch.. but if there thicker than all 12 would be better... thank you .. Katrina
[email protected]
I like fixing stuff.
Comp Cams sells lash caps that fit on top of the valve stems and change the angle of the rocker arms. It's also possible to put shims under the rocker shaft stands, raising the pivot point of the rockers.
Capital letters and punctuation are your friends- - - -your post is almost impossible to read.
