3 members (Peggy M, 2 invisible),
58
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#8824 01/05/2004 11:10 PM | Joined: Nov 2003 Posts: 113 Member | | Member Joined: Nov 2003 Posts: 113 | Okay, with my (engine) head being rebuilt, I decided to check out the push rods, lifters and cylinder walls and all looked great. So I turned over the engine and with luck the #1 piston ended dead up, with both lifters down. I checked the chrome timing ball on the flywheel and she is dead center on the pointer in the flywheel opening. Sooooh, this means that my timing set-up is correct from a cam perspective. With that in mind, should my points just be opening, be open, or be closed? I'm concerned since prior to taking the head off I replaced the vacum advance and had to pull the distributor to do it. I had a (#%$#^%) dickens of a time getting the distributor back in place. In essence, I might be one tooth off. Any way to check??
Thanks much for the insights!!
Bruce (I love My Truck) Miller
1954 5 Window 3100 Chevy Pickup - Driver 1929 **** Model A Pickup - Restoration
| | | | | Joined: Jul 2003 Posts: 252 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 252 | Hey Bruce, I've just discovered I have that very problem with the vacuum advance and am getting ready to pull the distributor to change it out. The biggest problem I got now is I can't find a replacement vacuum advance. I thought I had one on a spare distributor, but turns out it is a different animal. Can you point me in the right direction where I can find one? TIA, Tony | | | | | Joined: Sep 2002 Posts: 158 knuckle head | | knuckle head Joined: Sep 2002 Posts: 158 | Bruce, with the engine timed like you describe,the points should just be opening, with the rotor pointed towards the number one cylinder plug wire on the cap.When you feel you're close, just rotate the rotor ever so slightly clockwise, check for the points just opening.You can use test lights, buzzers or a cigarette paper, but a sharp eye is just as good. | | |
