1 members (GRNHydra), 87 guests, and 3 robots.
Topics128,095
Posts1,056,494
Members48,444
Looking for a picture of how the splash apron brackets attach to the running board and apron. Thanks
No photo. But, it is shown on sheet 17.00, section 11 in the assembly manual. Basically, the bottom of the apron bolts to the top flange of the running board in two locations (I believe). The top rear of the apron bolts to the rear fender. The top front of the apron bolts to a brace/bracket that is bolted to the running board (step portion) with a carraige bolt.
Oops, you asked about the bracket. Bottom of bracket to running board with carraige bolt. Middle of bracket to splash apron at bottom edge flange with regular bolt/washers/nut. Top of bracket same as middle. Hope that helps.
Thanks, so there's a carriage bolt that goes through the running board to attach the bracket. I think I've got it.
Thanks for the info and pictures!
Here are the fastener requirements for the aprons on each side:
Apron to Fender:
1 - - - (#121887) 1/4-20 X 3/4" hex head bolt
1 - - - (#120380) 1/4" lock washer
1 - - - (#120386) 1/4" washer
1 - - - (#134551) 1/4-20 hex nut
Apron to Running Board:
3 - - - (#120706) 1/4-20 X 1/2" hex hed bolt
3 - - - (#120380) 1/4" lock washer
3 - - - (#134551) 1/4-20 hex nut
Apron Support to Running Board:
1 - - - (#120518) 1/4-20 X 3/4" carriage bolt
Apron Support to Apron:
1 - - - (#120706) 1/4-20 X 1/2" hex hed bolt
Apron Support to Frame & Apron:
The running boards are currently off of my '54 3104. I plan on using stainless steel fasteners. Let me know if you need more pics or discriptions.
- Lonnie
My '54 3104
