8 members (Otto Skorzeny, 68ironhead, 3B, Jon G, Gdads51, NJC, 2 invisible),
104
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,130 Posts1,056,369 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 7 New Guy | | New Guy Joined: Sep 2011 Posts: 7 | Looking for a picture of how the splash apron brackets attach to the running board and apron. Thanks | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | No photo. But, it is shown on sheet 17.00, section 11 in the assembly manual. Basically, the bottom of the apron bolts to the top flange of the running board in two locations (I believe). The top rear of the apron bolts to the rear fender. The top front of the apron bolts to a brace/bracket that is bolted to the running board (step portion) with a carraige bolt.
Oops, you asked about the bracket. Bottom of bracket to running board with carraige bolt. Middle of bracket to splash apron at bottom edge flange with regular bolt/washers/nut. Top of bracket same as middle. Hope that helps.
| | | | | Joined: Sep 2011 Posts: 7 New Guy | | New Guy Joined: Sep 2011 Posts: 7 | Thanks, so there's a carriage bolt that goes through the running board to attach the bracket. I think I've got it. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Sep 2011 Posts: 7 New Guy | | New Guy Joined: Sep 2011 Posts: 7 | Thanks for the info and pictures! | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Here are the fastener requirements for the aprons on each side:
Apron to Fender: 1 - - - (#121887) 1/4-20 X 3/4" hex head bolt 1 - - - (#120380) 1/4" lock washer 1 - - - (#120386) 1/4" washer 1 - - - (#134551) 1/4-20 hex nut
Apron to Running Board: 3 - - - (#120706) 1/4-20 X 1/2" hex hed bolt 3 - - - (#120380) 1/4" lock washer 3 - - - (#134551) 1/4-20 hex nut
Apron Support to Running Board: 1 - - - (#120518) 1/4-20 X 3/4" carriage bolt 1 - - - (#120380) 1/4" lock washer 1 - - - (#120386) 1/4" washer 1 - - - (#134551) 1/4-20 hex nut
Apron Support to Apron: 1 - - - (#120706) 1/4-20 X 1/2" hex hed bolt 1 - - - (#120380) 1/4" lock washer 1 - - - (#120386) 1/4" washer
Apron Support to Frame & Apron: 1 - - - (#120706) 1/4-20 X 1/2" hex hed bolt 1 - - - (#120380) 1/4" lock washer 1 - - - (#134551) 1/4-20 hex nut
The running boards are currently off of my '54 3104. I plan on using stainless steel fasteners. Let me know if you need more pics or discriptions.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | |
