| | | Forums66 Topics128,176 Posts1,057,121 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 43 | We pulled the old 216 and 4 speed trans from my 48 PU this past weekend. I have a 235 I am getting ready to put in it's place. Are the intake and exhaust manifolds interchangeable from a 1951 216 & a 1954 235? If so I am going to take them off the 216, clean them up good and paint them then stick them on the 235 down the road.
Keith
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | It can be done, but the ports on the 216 are smaller than the 235. You will not be able to use the port rings to align the intake due to the difference in size. The 216 intake is also setup for a smaller carb, which may result in some power loss.
Bill Burmeister | | | | | Joined: Aug 2012 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 43 |
Keith
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I have used 216 manifolds on 235's many times. works fine.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | Like Dave said....Works fine. But only as a unit.
As a rule, you can not mix and match a 216 intake with a 235 exhaust, or vice versa.
The heat box bolt holes do not line up.
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Aug 2010 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 69 | In the process of doing exactly that. I have a 57 235 and am putting on a 216 manifold. Got the ring insert adapters from a guy in Arlington WA $22.29 to my door, Buffalo Enterprises. We shall see if all is good this weekend. Eric | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Just a heads up
Try a test fit when you get your adapters When I received mine they were a bit to thick. The OD was fine. I had to dress them down with a file.
Could of been a source for a leak
Good luck | | | | | Joined: Aug 2012 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 43 | Thanks fellows for the information and as this allows me to clean up and paint one set while I use the others. Thanks again.
Keith
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Just a heads up
Good luck This advice is important whether you use the adapters or you use the normal rings. This problem is not necessarily due to poor quality/thickness adapters (or rings). If the joint-surface on the manifolds (and/or head) has been ground/leveled/etc this might result in the ring being too "thick", and this would prevent the manifolds from being tightly attached-to head (resulting in leaks). In this case, as DADS50 stated, you have to dress/sand/grind off a enough material to allow a tight fit. | | |
