| | | Forums66 Topics128,021 Posts1,055,348 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#88240 10/14/2002 10:21 PM | Joined: Jun 2002 Posts: 19 Member | | Member Joined: Jun 2002 Posts: 19 | I have no cab ground - apparently if there was one it burned off. Where should it be and what size wire should I use? Thanks
If you think you can or if you think you can't, either way you're right.
#88241 10/15/2002 8:10 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | The shortest distance to the battery ground on the frame,which should be grounded well .You can not have too many ground straps(within reason). Make sure they are clean and tight and use a little dielectric grease to eliminate/retard corrosion.
#88242 10/15/2002 8:40 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | If you're running only standard accesories, 10 gauge wire will do. Now, if you add in a/c, a 1 megawatt stereo  , and all the other goodies, I would go with no less than gauge 0. With most setups, a 6 or 8 gauge wire will be big enough.
Fred 52 3600 69 C-10
