9 members (Gdads51, rfs56trk, FAST55, HandyAndy, 3B, Shade Baby, Hanks custodian, Wally / Montana, Otto Skorzeny),
51
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,038 Posts1,055,584 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 103 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 103 | Is it worth trying to clean up my rusted rims, or should I just by new ones? The inside of the rims have a little bit of pitting, and even after cleaning up with a wire wheel, there's still some bumpiness to the surface. I don't know how well a tire will seal against the rims. Also, I have 2 6.50 x 16 rims, and 2 7.00 x 15 rims. I don't think the truck (38 half ton) would have come with two different tire sizes, would it? | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | No, it would have had 16 inch wheels all around, I believe. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | They may leak if you run tubeless tires but with tubes they shouldn't leak. I would still make sure there is no rough areas where the tube seats. You should not run tubeless on these old rims. | | |
