| | | Forums66 Topics128,147 Posts1,056,805 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 159 | Hello all, I read the tech tip, but I must be missing something. The tip says to remove the three screws that secure the door latch, and then remove the two small screw below that hold the rear channel for the window. That's where I hit a snag. I can stick my arm in and move the channel around a bit, but I cannot (without forcing it) get enough clearance to work the latch around it to get it out. Please, what am I doing wrong? Thanks!! Harry | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | You need to completely remove the door latch first. Then there are two small screws near the bottom of the door (outside of door). There is also a screw near the top of the channel inside the door (sometimes missing) that and the latch hold the channel in place. Once the latch is dropped inside the door remove it and the weatherstrip channel through the access panel if you are doing both doors mark the channels because they are R & L hand. | | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | I found a screw under the door weatherstripping on my '48... | | | | | Joined: Jan 2011 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 159 | Thanks, Brad. I could not get to the little screw just below window level - it was covered over by the replacment channel-stripping. But I was ablt to work the latch around the channel, once the two lower screws were removed. Why did they make it so hard? All it needs is an access plate.
Anyway, thanks for your help.
Harry | | |
