6 members (Steelonsteel, dt235sd, Mike Burns, Youngin' Tut 59, Hotrod Lincoln, Hanks custodian), 65 guests, and 2 robots.
Topics128,066
Posts1,055,871
Members48,428
#882052 09/11/2012 11:41 PM
How do I get the oil dipstick tube out of my 1954 235 block without squishing it. ohwell
Bruce
My Trucks
Stuff I Collect
Stick a 5/16" bolt or rod inside and clamp around that area.
My Blog
I think it's just a friction fit, correct?
Bruce
My Trucks
Stuff I Collect
yes it is bruce,if you can get to it from the bottom use a 5/16 or the same size as your inside dia.tube on top and then clamp it and the use a smaller rod from the bottom to drive it out.putting the smaller rod through the tube to touch the bolt or rod and drive it out. dan
http://s1055.photobucket.com/user/baldybenny/library/
1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
