2 members (Charles in CA, TexasJim50), 109 guests, and 5 robots.
Topics128,094
Posts1,056,058
Members48,433
Where does the stock 6 cyl/4spd mount? More forward or rear mounting position?
I am working on a truck that i goy in pieces. Thanks
Hard to tell, not knowing if this is a '29, '39, '49 or ?. But generally the front motor mount sits on the front crossmember and the bell housing sits on the next crossmember.
It is a 1965 c10. The motor mount tower area of the frame has 3 or 4 holes for different mounting positions of the drivetrain front to back. I just need to know if the motor mount tower braces go on which of the selected bolt holes.
