1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 124 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 124 | Where does the stock 6 cyl/4spd mount? More forward or rear mounting position?
I am working on a truck that i goy in pieces. Thanks
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Hard to tell, not knowing if this is a '29, '39, '49 or ?. But generally the front motor mount sits on the front crossmember and the bell housing sits on the next crossmember. | | | | | Joined: Jun 2011 Posts: 124 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 124 | It is a 1965 c10. The motor mount tower area of the frame has 3 or 4 holes for different mounting positions of the drivetrain front to back. I just need to know if the motor mount tower braces go on which of the selected bolt holes.
