1 members (Wickedbass),
33
Mod | | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#88181 01/21/2005 1:42 AM | Joined: Jul 2004 Posts: 102 Member | | Member Joined: Jul 2004 Posts: 102 | Hey everyone, I have a problem.
I switched over to 12 volts using the EZ-wire harness a while back. I have everything working the way I like but I notice that when I have my headlights on the amp meter in the dash reads on the negative side.
I have a 94 amp alternator (12SI) from an '84 camaro (new). Shouldn’t this be strong enough? Is there a possibility I have some wires crossed somewhere that might cause this?
I have a 10 watt resistor that I understand should be in the alternator circuit somewhere, but I don’t know where, would this cause the problem?
I have also noticed that the alternator gets very hot to the touch after it has been running for a while, could this indicate a problem?
I really need some help with this one guys, I can’t figure it out.
1948 3600 thriftmaster
#88182 01/21/2005 8:08 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Hey, Gecko You can't do any better than your Delco 12si 96 amp alternator ... that's not your problem. Your headlights should not be causing a draw though -- something isn't right there -- double check all your wiring on your headlights; make sure you have a good clean and solid ground. You might consider headlight relays ... see This Another thing that comes to mind is *where* your gauge is reading your voltage (amps) from. Many people piggy back the third wire to the alternator to the back side of the alternator and that is NOT the way to properly read voltage. I ran that wire to a terminal block I installed on my firewall (under the hood) where I run power to everything (like my headlights) and THAT tells my gauge how much power I have, where it counts; an honest and true reading. See This
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
#88183 01/21/2005 3:33 PM | Joined: Jul 2004 Posts: 102 Member | | Member Joined: Jul 2004 Posts: 102 | Thanks Horvath, I read your site about a dozen times comparing it to my set up and found there were a few things wrong. I managed to get it hooked up properly and when I did the amp gauge shot up to the positive side and everything got a lot brighter. Thanks so much for the help, and thanks for documenting your system so well and so clearly for the rest of us!
#88184 01/22/2005 8:41 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | I'm GLAD my articles helped you out, bro'! It sure makes you feel good when things are done right, doesn't it?
#88185 01/22/2005 2:39 PM | Joined: Jul 2004 Posts: 102 Member | | Member Joined: Jul 2004 Posts: 102 | It sure does, I spent the better part of yesterday trimming wires and eliminating unused curcuits. Under the dash now looks clean and tidy, not like a rats nest.
#88186 01/24/2005 4:11 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The amp meter tells you current is flowing, which does not always mean something is wrong.
If your amp meter is showing negative when the lights are on it means your truck is wired so that current to the lights is going through the guage.
That may or may not be a problem.
If you are using the stock amp meter your alternator may be able to produce enough power to burn out the guage. But unless you are running some accessories that use lots of power you are probably okay.
What wiring diagram did you use to wire your truck?
How is the alternator wired? Is it wired as a '1-wire'?
If your headlights don't pull some current they are burned out or disconnected. What that means to the amp guage depends on how things are wired.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#88187 01/24/2005 8:53 PM | Joined: Jul 2004 Posts: 102 Member | | Member Joined: Jul 2004 Posts: 102 | I didn’t use a wiring diagram; I just copied what was original as I went along. I have wired the alternator as a 3 wire; I didn't piggyback any wires etc. I added the idiot light to the circuit from the alternator and now when I start the truck it will show a huge discharge on the gauge until I rev the engine a little, then the idiot light turns off and I get a strong charge for a minute or two then it tapers of to no charge/discharge on the gauge. I'm pretty sure everything is working how it should now.
