| | | Forums66 Topics128,074 Posts1,055,913 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 45 | I have a 59 panel. With the standard ride height, will 30" tires fit? What about 32?
thanks
Is rust considered a body style?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | that's about original, which would have been 6.70x15 or optionally 6.50x16
Bill | | | | | Joined: Aug 2012 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 45 | 6.50x16 is the tread and rim right? What about the diameter?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | original diameters are about 28-30", check tire conversion charts, the height isn't as critical as the width of the rim - 5.5" original ... if you're looking at modern sizes, do you have 15's or 16's? unless you go to real truck tires you're not likely to find anything 32" unless it's way too wide for the stock rims or you're using aftermarket modern rims, which will likely cause problems with full lock turns
Bill | | | | | Joined: Aug 2012 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 45 | I'm looking to use truck tires. Considering 30 or 32" to help with mileage. The current rims are 15, but maybe it's better to go with 16s?
I'm planning to use the vehicle as a part-time driver, not a show car.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | 700R15 Yokohama 10 ply, about the tallest narrow radials I found .... but you won't do much for mileage with tires, you might look for an original 3 speed overdrive or spring for the 3.38 rear gears from PatricksBill | | | | | Joined: Aug 2012 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 45 | Thanks, Bill. The current thinking is the SM420 with 3.38 gears. The larger tires will keep the RPMs in the mid 2000's on the highway. (Assuming the on line converters are correct... )
| | | | | Joined: Aug 2012 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 45 | I need to replace the wheels on this truck. Anyone have an idea of what offset will allow the larger tires?
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | It's going to take a combination of offset, backspacing, and wheel width to get larger tires. Depending on what width and rim diameter you're looking at will determine the other 2 dimensions. As Bill mentions, tall and narrow 15s are getting hard to get, you almost have to go wider. On the otherhand, tall narrow 16" tires can still be easily found, with 215/85/16 (30.4" tall) and 235/85/16 (31.7" tall) being the common sizes. With the 15s, you almost have to get into floatation sizes to get a tall tire, 30x9.50x15 and 31x10.50x15 being the common ones. The are also a 32 and 33 inch tall 15s, but they start getting rather wide, and really push the limits on fedner clearance, and swell as stress on the front wheel bearings and steering gear. For the 30x9.50 and 31x10.50, you would want an 8" wide wheel, 3"-3.50" backspace, and -25mm offset, which is a standard GM 4x4 fitment for '73-'87 (I'm running this setup on mine). For the 16s, which will the tricky one to find, you would want a 6.5"-7" wide wheel, 3"-3.5" backspace, and 0mm offset, though a little bit of negative offset, say about -15mm, probably won't hurt anything.
Bill Burmeister | | | | | Joined: Aug 2012 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 45 | thanks '55, that is exactly what I was looking for
