| | | Forums66 Topics128,138 Posts1,056,751 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2012 Posts: 2 Moderated | | Moderated Joined: Apr 2012 Posts: 2 | Just putting it back together after a frame off restore and we closed the hood and the pin was not aligned properly and it is now stuck in the lower latch. So, we can't get the hood open. Anyone have any suggestions as to how to get in there to pry the pin to free it from the latch? | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Welcome to the bolt'  This happens occasionally. Try pushing down on the hood in a front to back and in a downward motion and have someone try and move the lever hard. We have discussed this before and several of us have had the same problem through the years. Here's a previous post that has the manual information that may help. | | | | | Joined: Jul 2012 Posts: 17 New Guy | | New Guy Joined: Jul 2012 Posts: 17 | I've seen this on mine before, if the hood is a little out of alignment or twisted It will hang up in the hole, if the front to back doesn't do it I've had to shove mine off to the side a little. look at the way the hood is sitting and see if it looks like it's off to one side or the other. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The last time this came up, the solution was forcing it side to side at the front. There mat be a way os loosening some of the hinge bolts from inside the cab. I know this is frustrating and could be a real bear to deal with. | | |
