1 members (Brian Moore), 95 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#881275 09/09/2012 11:16 AM
Can anyone tell me if a 235(chevy) and a 228(gmc) can use the same bellhousing? Will the same starter work with both engines? This is going into a 50' A.D. pickup.Thanks for your help. Luv this site!! Dave
oldburbs #881295 09/09/2012 1:12 PM
1948 through 1953 GMC and Chev clutch housing will interchange.
crenwelge #881303 09/09/2012 1:50 PM
Starters will also interchange as long as we are talking 6 volt to 6 volt or 12 volt to 12 volt. The 228 flywheel will have a 6 volt ring gear. The 235 could have the 168 tooth 12 volt ring gear.
The 6 volt and 12 volt starters will bolt up to the bellhousing without issue. Just have to make sure you have the correct flywheel ring gear. A 6 volt starter will run fine on 12 volts, but a 12 volt starter will not run on 6 volts.
thank you BOTH VERY MUCH for your valuable info. That will make my job a whole lot easier. Appreciate your help
Dave
