| | | Forums66 Topics128,203 Posts1,057,412 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 112 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 112 | What the heck is this relayish-looking thing mounted on the firewall forward of the steering column in my 1969 C-10? The plug is hanging there beneath it. Any ideas?
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Looks like a horn relay. I can't remember on 69 where they are, but I thought they were under the hood. Maybe not. | | | | | Joined: Oct 2010 Posts: 171 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 171 | Don't want to be a bonehead but did you follow the wire? My git says horn or maybe a turn signal flasher
....David
| | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Looks like a horn relay but like 54barnfind said, did you follow the wire? | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | If it is above the steering column and slightly toward the outboard side, it may well be part of an abortive attempt at early pollution control. I had one on my '71 C10 that has a 350 and I've seen them on several other C-10s as well. As I understand it they helped hold a "decel" solenoid in the extended position until the brake light switch cut it out.
best wishes,
Les | | |
