2 members (JeffA, FishinToms53), 170 guests, and 1 robot.
Topics128,162
Posts1,056,938
Members48,458
#876442 08/21/2012 1:34 PM
Does anyone know what the hard brake line size should be on a 47 with Huck brakes? I suspect the lines on my 47 are not stock and I want to keep it all stock. One of the lines ruptured along the frame rail. Thanks for all the great help in the past!
The line is 1/4 inch for all the hard lines on the 47. I found this out after removing all the brake lines. Some were 3/16 and the most were 1/4 inch. There was a long section of compression fitting pipe along the frame rail to the rear. What a mess!
i have kind of the same problem...my 48 gmc 1/2 ton came with all 3/16...i ordered prebent lines, and i got 2 lines 3/16 and 5 lines 1/4...HELP
