| | | Forums66 Topics128,162 Posts1,056,917 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 10 New Guy | | New Guy Joined: Oct 2010 Posts: 10 | Does anyone know what the hard brake line size should be on a 47 with Huck brakes? I suspect the lines on my 47 are not stock and I want to keep it all stock. One of the lines ruptured along the frame rail. Thanks for all the great help in the past! | | | | | Joined: Oct 2010 Posts: 10 New Guy | | New Guy Joined: Oct 2010 Posts: 10 | The line is 1/4 inch for all the hard lines on the 47. I found this out after removing all the brake lines. Some were 3/16 and the most were 1/4 inch. There was a long section of compression fitting pipe along the frame rail to the rear. What a mess! | | | | | Joined: Oct 2011 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 118 | i have kind of the same problem...my 48 gmc 1/2 ton came with all 3/16...i ordered prebent lines, and i got 2 lines 3/16 and 5 lines 1/4...HELP | | |
