| | | Forums66 Topics128,274 Posts1,058,428 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 24 New Guy | | New Guy Joined: Jul 2011 Posts: 24 | Does anyone know the correct length for the oil bypass canister lines on a 55.1 1/2ton with a 235??? Found a few companies that sell them in pairs, but which ones are the correct length...14in/18in, 13in/19in, 15in/20in.
Also, does anyone sell the restriction fitting to maintain oil pressure when using the bypass canister...Can't seem to find that. I believe it is a fitting with a 1/16th inch orifice???
Thanks, -Paul | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | If you're using an original bypass filter, the restrictor is built into it, no additional restriction is necesary.
Bill Burmeister | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | If you have the 1954 AC oil filter, get the longest set of lines that you list.
15" and 20"
Where did you see these for sale? I need a pair.
| | | | | Joined: Oct 2006 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 99 | Yes, just took mine off a 56 gmc 270, cleaned and painted, the restrictor is in the top threaded fitting pressed into the canister. I wondered why the small orifice.
Dave | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Thanks, Paul,
I do not know what length lines were originally supplied.
Supposedly, the lines were longer in 53-55 compared to 1952. I have bought sets of lines from reproduction parts vendors that were too short.
Maybe someone with an SC-653 has installation instructions with part numbers? Supposedly, the 1954 AC hose part number included the length of the hose in the code?
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | |
