Help!
New temp gauge. New Sender Unit. Temp gauge needle still swings 360 degrees
past hot to jam up against the needle stop. Requiring me to take the dash out. Pull the temp gauge. Spin needle
back around to where is should rest on the other side of the needle stop.
The new gauge is from Chevy Duty. After having me "reverse wires" (which I did until smoke started coming out of the dash) they told me to buy a new sender unit. Bought it. Still same problem.
I don't have the original pink ignition wire for the gauge so I spliced into another pink wire from the ignition. Is it possible to be spliced into the wrong power wire?
This is on a 1959 3800 Chevy. I've even tried a voltage reducer on the chance chevy duty sent me a 6 volt gauge. I'm at my wits end and almost fed up with my old truck.
Has anybody ever experienced this or have advice?
Appreciate it.
Jacob
