4 members (Otto Skorzeny, Hotrod Lincoln, 32Fordpuchoptop, Nhluvstruck), 164 guests, and 1 robot.
Topics128,114
Posts1,056,283
Members48,439
#878848 08/29/2012 6:35 PM
Can someone explain gluing to me or direct me to a site with more indepth info. I'm going to need to do some work, have welder to do panels but no experience. I seen a few members speak of gluing in posts and this maybe something I'd try but I can't graspm the concept. Give a material name to research and any info you think might help, please.
If they don't find you handsome,they should at least find you handy! ~ Thanks RED GREEN
1957 Chevy 3800 :: In the Stovebolt Gallery
More pix on Flickr
Check out the recent thread on Lord Fusor...
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=877414#Post877414
Basically the strength of the joint in using the adhesives is the overlap of the panels, so most repairs are installed using a stepped flanging process to accomodate the overlap but still keep the outer edges of the panels flush. The main detractor to using this method is the appearance of ghost lines at the seam in the final finish, as stated in the other thread, and/or delamination of the joint from improper cleaning or application methods.
What I normally suggest to people with welders, is to practice with scrap pieces to get the welder settings dialed in for a full penetration weld when butt welding, using the same thickness metal as you will be working on. Then once you feel comfortable with that, use the floor pans as your "practice area" to butt weld in the repair panels so that when you do get to working on the outside panels where it is more critical, you will feel more comfortable in tackling the repairs there.
Where some may suggest to use flanging on floor pan welding as it is easier, or nobody will see it, or various other reasons, bottom line is it makes for a repair subject to water intrusion and thus future rust. More importantly, flanging for either method, welding or adhesives, opens up the vehicle to scrutiny of prospective purchasers in the future that will see the flanged repair as substandard resulting in a possible adverse effect on the price. Where adhesives may serve as a viable option, any repair panel that does not appear to look as factory installed will be more likely to open up this scrutiny.
Here is a good read on welding in patch panels that may help you build some "book experience" to gain the confidence to use the welder for your repairs..
http://www.garagejournal.com/forum/showthread.php?t=53534
MPandC is correct about using flanging and the possible water/rust issues. What I have done with good results, is seal the inside surface of a flanged panel (after welding,) with fiberglass resin. It is thin enough to go where gravity takes it. Of course, metal must be shiny clean. Should last longer than most of us!
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
I just use normal seam sealer on lapped seams. Most of these trucks have many lapped seams. Nothing wrong IMO with gluing non-structural metal. On newer cars I have often seen the metal tear before the glue fails-it simply won't come apart. Grind both sides clean w/50 grit for good "tooth" for the glue.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Thanks fella's, I will take this info into consideration. I did find a site that explained alot. I think I will try to weld in place and go from there.
More pix on Flickr
