3 members (Hotrod Lincoln, Bill Hanlon, Otto Skorzeny), 205 guests, and 7 robots.
Topics128,107
Posts1,056,221
Members48,436
#879496 09/01/2012 12:22 PM
64 Panel with the stock turn signal switch, and I have no idea what goes where
turn signal wiring
Three whites,then yellow, pink, black and the green, which I think is the horn.
I'm using the EZ wiring kit, and kinda disapointed in the lack of support from them,two phone calls and an e-mail from me with no response.... ohwell
Anybody have the color coded wiring diagram?
Good Karma Panel Truck
Don J wave
1964 Chevy Panel
"The Good Karma Project"
More pix on Photobucket
1957 Chevy Panel
May be goin' to Hell in a bucket, but at least I'm enjoying the ride! ~ Jerry Garcia
got a shop manual? colors should be the same as factory and the factory wiring diagram has colors marked .... earlier units yellow goes to the flasher unit - if you put an ohmeter on green wire to ground and press the horn, it should show a short if that's the horn wire
Nope, no manual...I was hoping someone here could look this up for me computer_punch
Don J wave
1964 Chevy Panel
1957 Chevy Panel
check your other thread, I looked up a repro switch with colored wires for ya
