1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#879499 09/01/2012 12:34 PM
Kinda disappointed in the lack of support....
The instructions are rather vague,it helps if you've done this sorta thing before, not for the first timer...
I've called twice, then sent an e-mail with a question about the turn signals....no response ohwell
Wiring help
Don J headscratch
1964 Chevy Panel
"The Good Karma Project"
More pix on Photobucket
1957 Chevy Panel
May be goin' to Hell in a bucket, but at least I'm enjoying the ride! ~ Jerry Garcia
On page nine(9) in the lower left corner( in case you didn't see it) are the GM TURN SIGNAL DIRECTIONS. Notice all the colors match GM originals except for the horn which you rightly fiqured
is green. I am not defending EZ Wiring's poor business sense in not responding to you, but remember their kit is a general wiring kit and not vehicle specific. That is why they instruct you to match up the new kit to your old wiring and eliminate new wires you don't need or don't forsee using in the future. If you don't have your old wiring,than a wiring schematic for your specific truck is a must.
Drew
I've read page nine(9), and the GM TURN SIGNAL DIRECTIONS do not match what is here on the 64 Chevy STOCK turn signal switch.
I see what EZ has labeled on their harness, what I can't account for is the colors coming from the stock switch.
The rest of the truck wiring is done, and I've eliminated the unused stuff.
This can't be too difficult as the truck just had right and left signals along with the horn...anybody have a wiring diagram for a 64 ?
The rest of the story
Don J wave
1964 Chevy Panel
1957 Chevy Panel
Don, it doesn't help to have numerous threads running about the same problem .... according to this there should not be multiple white wires to the switch - what makes you sure it's an original switch? how do you know it hasn't been re-wired before? why doesn't it have the plugs on the wires?
Here's what I've got
stock switch
The black and light blue on the right are the horn and indicator light for the shifter...
Then from left, white, pink, white...then grey, yellow, green.
Any ideas?
And thanks for the help thumbs_up
Don J wave
1964 Chevy Panel
1957 Chevy Panel
"stock switch" that's had the wires replaced - there was never multiple wires of the same color any year, there should be light and dark blue to the front lights [check the EZ harness], white, pink, purple go to the rear and brake sw, and I'm sure that color coding was standard by '55, still the same in my '67 manual - again, compare to the EZ harness - and the color codes should be on the wiring diagram in your shop manual ... you should be able to figure out which wire is for which side by checking with an ohmmeter while you manually work the switch, EZ will not be able to help you at all with that switch
