0 members (),
150
0
Mod | | | Forums66 Topics128,101 Posts1,056,180 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 65 | Hi Have a new Tank,( mounted below the bed) & new line to Stock reconditioned Fuel pump, Truck has been running but now I find that fuel is not been devivered to the carb. I disconnected the fuel pipe from the carb & attached a clear tube to it. I then sucked thru fuel until it was visible in the tube.
When I stopped suction on the tube the gas ran back down the hose
Is the suposed to be a non return system in the pump?
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | There are two valves in the pump. One of them should hold the fuel in the line so that it doesn't return to the tank.
Sounds like the fuel pump is bad. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
| | | | | Joined: Jul 2010 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 65 | Can the valves be replaced or unstuck? or do I need to get a new pump | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | You can get a rebuild kit or new pump from most of the vendors.
| | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Save yourself a dollar and pull the pump apart first.
If the "recon" fuel pump has had the valves put in incorrectly , it should be easy to just check them and ensure a proper installation is done.
