3 members (wilbur53, JW51, Otto Skorzeny), 150 guests, and 5 robots.
Topics128,088
Posts1,056,124
Members48,435
#879338 08/31/2012 6:17 PM
I noticed when starting to remove my 51's rear axles, to change the seals, that there was quite a bit of lateral travel in the left axle. What should I look at to see where the excess travel comes from and how do I remedy it?
I think he is talking about end play in the axle shafts them self's. That end play is adjusted by the center block/spacer that fits in between the ends of both axles. It is of little concern though. Group 5.422 in this link
My Blog
I have seen that the spacer block is used to adjust the end play but the play is all on the left side. Wouldn't a larger block make the right side overly tight in order to close up the left gap?
They make shims for the spider gear that is on the axle. That will push it closer to the block.
Time to pull the cover and have a look.
My Blog
