| | | Forums66 Topics128,162 Posts1,056,945 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 2 New Guy | | New Guy Joined: Aug 2012 Posts: 2 | Unable to buy/secure original cab and/or engine harness for my truck.Original is gone. Don't want hot rod harnesses. Anyone have dimensions/specs for box stock/no options original? Thanks. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | welcome to the garage rain, check the electrical links to contact Rebel Wire and Vintage Wiring of Maine, they both custom make harnesses from OEM specs - the "specs" anyone here might have would be the shop manual wiring diagram, which just shows the connections, not the measured layout, but a post in the parts wanted section might find you a good used harness Bill | | | | | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | It's been several years but for my '58 GMC I ordered a Chevy harness from Classic Parts. It fit everything just like it should. The only difference from the GMC that I remember was that the GMC has more dash lights so I just had to wire a couple more lights in series. Otherwise, it's perfect. | | | | | Joined: Aug 2012 Posts: 2 New Guy | | New Guy Joined: Aug 2012 Posts: 2 | | | |
