7 members (Jays58, tricordati, Otto Skorzeny, KEVINSKI, Gazz, JW51, Shade Baby),
147
Mod | | | Forums66 Topics128,095 Posts1,056,468 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | I've done a bit of research and come to a point where I'm on information overload and can't make a decision.
What are everyone's thoughts on boiling and sealing/coating a rusty tank vs buying a new galvanized steel or Ni-Tern (nickel plated) steel tank? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | New Tank rock auto offers a spectra tank, made in Canada ...rock auto...$145 plus shipping | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | If you have the option of a new tank I think that's the way to go. In my case I didn't have that option so I had the larger holes brazed shut then acid cleaned and coated my tank. Eight years later now and no problems. If you go with an acid cleaning and coating be sure to follow the directions. Those who don't have problems.
| | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | How much do you value your time? I feel that all the time you spend cleaning and getting ALL the rust out of the tank and then acid washing, drying, and coating it's cheaper to just replace the tank - unless you have a real odd ball tank. But the tank for yours only runs about one fifty. And you don't have to worry about missing a spot and having to re-do it again later.
Just my 2 cents............
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | | | | | | Joined: Jul 2012 Posts: 83 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 83 | New, if you can. I spent $70 on a reseal kit just to find out afterwards that the fuel pickup broke or rusted out and I'm sucking air now.
1953 1 ton panel
| | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Thanks guys! I agree that a new tank is the way to go.
Now, the question is, galvanized or Ni-Tern? Spectra tanks are Ni-Tern ... I've read that the Spectra tanks rust at the welds.
Tanks for AD trucks run about $150 on up but shipping puts it at or above the $200 mark and I, being in MO, pay tax at Jim Carter and Classic Parts.
PootersPanel - I was reading your post about that, did you get it sorted out? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Some of the vendors tanks are Chinese/overseas made.
Metric threads on bottom and inlets not lining up. Before you purchase ask a few questions
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I'd expect that Spectra tanks are about all you'll find except maybe some Chinese imitation, would like to see some references to the welds rusting, never heard that before ... Ni-Tern [nickel/tin] steel is the OEM approved material nowadays, and I believe Spectra tanks are externally coated after assembly, as well as having a warranty for use with E20
Bill | | | | | Joined: Jul 2012 Posts: 83 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 83 | BLUEMEANIE- not yet. I just ordered a pickup truck sender with built in fuel pickup. Gonna modify it to work.
1953 1 ton panel
| | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Whoa. Rock Auto has the Spectra tank for $159 shipped to my ZIP! Case closed, order placed.
...also, just spoke to a couple people at Spectra and they were as nice as can be.
red58 - With all the random links I followed I couldn't link you to the specific comments I read, they were just random posts in longer threads but it came up enough that I noticed. ...but not enough that its something I'd worry about. They all referred to "light rust at the welds."
PootersPanel - Good deal. Hope it all works out for ya. | | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | The PO had the tank "cleaned" and relined but, it only lasted about 5 years and it started to rust through again which created some real problems for me. I think relining is OK as long as the tank is prep'd properly and you want to do a down and dirty. As stated previously by others, for the cost, I would definitely go for new. | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | ^ Yup. Ordered yesterday.
Peter_H - I think that's what is happening to me. The PO had the tank relined and I'm seeing the aftermath 5-6yrs later. There's more and more rust showing up in the fuel and it is starting to look cloudy (but not pink/rust cloudy) all the time even with a new filter after the tank.
I ended up finding a discount code and getting the Spectra tank delivered for under $150 from RockAuto. At that price it was a no brainer. | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Wow. RockAuto is awesome! I ordered the tank shipped at 4:30p on Thursday for significantly less than any one else had it listed with out shipping and it arrived in two days via FedEx!
Also when I had technical questions they couldn't answer, they three-way'ed Spectra directly!
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | might be a good idea to inspect that new tank. When I looked at the bottom outlet of my new spectra tank I found this. ...pic... ...pic... It not rust but some dried up oil or preservative maybe from the assembly process. I was able to clean it up easily with solvent. Just didn't want to introduce any small particles into the fuel system good luck | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | DAD, that looks like flux residue from soldering the fitting in, gas would dissolve it the same as the solvent did
Bill | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | could be flux, I dont know it was in the packaging also ...pic... ...pic... didnt want to take any chance so I cleaned it up | | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | BLUEMEANIE, do inspect the inside of the tank as DADS50 said... When I got mine it had flash rust in it from getting wet during shipping... ROCK AUTO had no problem replacing it...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
| | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Will do. Mine arrived oily on the outside like DADS50's.
I'm wondering what, if anything, to coat the outside of the tank with... ? What are you guys using? I was thinking something like a rubberized undercoating or something. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | What are you guys using? I was thinking something like a rubberized undercoating or something. I didnt coat the outside. ...pic... if you do decide to coat it make sure you leave a spot for a good ground On the sender otherwise your fuel gauge wont work. | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | ^ You're not worried about the outside rusting at all? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I'm wondering what, if anything, to coat the outside of the tank with... ? What are you guys using? the Spectra tanks have a lead/tin coating on the outside, adding anything else will not be an improvement and may not stick for long Bill | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | the Spectra tanks have a lead/tin coating on the outside, adding anything else will not be an improvement and may not stick for long Bill Good info above, ^ You're not worried about the outside rusting at all? I don't live in an area where rust is a problem. I didn't consider painting it. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the rest of the truck will be dust before the outside of a new tank inside the cab rusts  the original rusted from the inside out due to condensation, always keep the tank full in storage to lessen that problem Bill | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | the Spectra tanks have a lead/tin coating on the outside, adding anything else will not be an improvement and may not stick for long Cool. Good to know. | | |
