| | | Forums66 Topics128,167 Posts1,057,015 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 29 New Guy | | New Guy Joined: Aug 2000 Posts: 29 | I am starting the priming/painting process on the hood of my '37 1/2 ton. This will not be a "show" car, so I am not taking the four sections of the hood apart but want to spray it as a unit. Does anyone have experience with doing this? Any advice? How to I make sure the hinge area gets covered, yet moves? Any advice is greatly appreciated. Thanks, CAB | | | | | Joined: Sep 2010 Posts: 1,717 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,717 | Christopher, I recently did my '38. I separated into 2 halves, then hung them from the ceiling. hood I hung them high enough so I could get under to cover the hinge area. I still had a small touch-up afterwards. Good Luck  Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Jul 2002 Posts: 166 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 166 | I took my 37 hood completely apart, separating all 4 pieces. I will be hanging mine to paint them too as Wayne67vert did. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Hi Chris,....taking the hood apart is actually pretty easy. The center section hinge just unbolts. The two side panels have a thin rod threaded thru the hinge. Soak it with rust buster for a while and it should slide out with a few whacks. I replaced mine with a piece of stainless steel rod that only cost a few bucks. I think you would get a much better job that way. | | |
