Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
including
8 members (41 chev, Charles in CA, Peggy M, Bucker, klhansen, Nick in Manitou, Otto Skorzeny, 1 invisible), 110 guests, and 6 robots.
Topics128,270
Posts1,058,408
Members48,485
#878941 08/30/2012 1:09 AM
I've found a set of 17" 6 lug rims that came off a 1947 chevy on the web.
1. Question will they fit a stock 1957 GMC 100 6 lug with clips
2. Will or should the 57 caps fit?
3. Is their a better solution for the factory look?
Thank you, for any input.
Jim
Make Love your strongest weapon. Compassion your shield and forgiveness your armor.
Are these 17 inch artillery wheels?
If they fit an original 1/2 ton 47 chevy, they will fit your 57 gmc without clearance issues.
I found some 16 inch artillery wheels several years ago to use on my 1940 gmc. The hubcaps from my 59 fit the centers without any modification. I had my 16 inch arty wheels widened to 7 inches, and plan to use either a 750-16 whitewall tire or a 235/85/r16 tire.
My current 59 gmc 1/2 ton has the 6 lug 15X8 ralley wheels from a chevy 4wd.
Here is a thread showing how to put vintage hubcaps on the more modern 4x4 ralleys.
https://www.stovebolt.com/ubbthread...ubcap+adapter&Search=true#Post834210
No they are not artillery wheels
