1 members (baldeagle),
62
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | Are you supposed to use the choke on these engines (235) on first startup of the day in warm weather? I was using it briefly every morning with good results. I found I could shut it off quickly and the engine would run on its own. But I just replaced the points, dist cap, and condenser and now I find it doesn't seem to like the choke. It stumbled with a lot of smoke. I pushed it all the way in and the truck ran fine. It's usually in the high 80s, low 90s here this time of year. I wonder if all it needs is a quick pump of the gas pedal.
1956 Chevy 3200
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | let the truck tell you what's needed, no "supposed to" involved - in warm weather you might get by with no choke at all, even cooler mornings, first start shouldn't need more than say 1/4 choke for just the first couple seconds, never full choke - it may keep an idle without any choke, but need a small amount when ya first move out to keep it from bogging until it's up to temp
Bill | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | If it doesn't need the choke when started from dead cold (12 hours off) idle mixture is too rich. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | "need the choke" does not define how far the knob is pulled out, and "dead cold" when the ambient temp is 85-95 is much different than "dead cold" when the temp is 40-50
Bill | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I'm with Bill. My '38 rarely needs the choke to start but once started a bit of choke helps keep the stumble monster at bay. Even that usually lasts no more than a minute, two when it's really cold.
| | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | I went out and started it today. I had the choke out just a little way, and that seemed to be where the engine was happiest on startup. I had given it too much choke the last time.
1956 Chevy 3200
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | If I am starting either my '50 or '40 after sitting over night I always pull the choke out, soon as it fires I push it half way in and within a couple minutes of running it gets pushed in most of the way and after another couple minutes it goes all the way in. This time of year I don't even think about using the choke the rest of the day/evening and things start right up. | | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | Yeah, the only time I use mine is in the morning on first startup. Then it's not necessary for the rest of the day. I haven't had the truck for a winter yet, at least not with a running engine.
1956 Chevy 3200
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I never use the choke on mine, it's a 261. When the mornings get a bit cooler, (it's already down to 50F) I'll need to use it. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Every engine/carb is a little different. You want to do what works best. That said you don't want to use any more choke then nessesary. Excess washes oil off the cyl. walls, polutes the oil & carbons the spark plugs. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
