1 members (Hotrod Lincoln),
88
Mod | | | Forums66 Topics128,014 Posts1,055,325 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#87864 01/18/2002 12:42 AM | Joined: Jan 2002 Posts: 84 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 84 | I have a 54 1\2 ton 5 window deluxe cab that I purchased for $100.00. The cab must have came from a 54 that was a automatic because it has no clutch pedaloor hole for one and it has a push button start on the upper right dash by the headlight switch. Has anyone heard of such a truck and if so can they point me in the right direction to find out more about it? thanks, marlo Valley Cruisers Car Club Central cal. | | |
#87865 01/18/2002 1:23 AM | Joined: Feb 2000 Posts: 6 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 6 | You are on the right track , I have a 54 3100 that came with a hydramatic and is as you described. I have changed the drive train to a stick , you will also find that the floor panels are different from the trucks with a stick | | |
#87866 01/18/2002 2:36 AM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | The starter on a Hydramatic Truck had a solenoid, hence the pushbutton switch over the headlight. The floor panel should have a small hinged door on the passenger side to allow for pulling the dipstick to check the tranny fluid.
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#87867 01/18/2002 8:09 AM | Joined: Jan 2002 Posts: 84 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 84 | thanks guys ! were many of these made and if so do they have a certain model number? I found out the hard way about the floor pan ...cut it up and welded it shut added a tranny cover from the 53 I had . put in a genie automatic swan stick shifter that looks and works well. I'm having problems with the gas pedal linkage. Running a 250 with 2004r tranny,500cfm elderbrock carb,clifford 4 barrel alum. manifold and stovebolt cast iron headers. you guys seem like pro's any suggestions as far as junkyard linkage that I may use or should I just but one from lokar? | | |
#87868 01/18/2002 6:01 PM | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | Marlo,
The Hydramatic trucks are fairly rare; they also usually came w/ 5-window cabs and the deluxe trim package: fabric seat cover w/mathcing door panels, two tone paint inside & out, stainless window trim, and other niceties.
Hydros were available in 1/2, 3/4, and 1 ton trucks: GMC in '53, Chevy in '54.
Frank McMullen 1941 Chevy dump truck 1949 GMC 100 pick-up 1954 Chevy 3600 pick-up 1955.1 4400 dump truck 1941 De Soto & other MoPars 1928 Model A F**D Special Coupe
#87869 01/19/2002 2:32 AM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I would have traded you a 5-window 54 cab/chassis (set up for a stock 4-speed) for your 5-window '54 set up for a stock automatic. I have the '54 Hydra-Matic drive train (and all other parts unique to this set-up) but not the cab/chassis. Anyone know where to find a '54 Hydra-Matic without a drivetrain?
Here are some other things that are different on a Hydra-Matic 1/2 ton in '54:
- different brake system master cylinder - different routing for brake lines - engine and transmission were a matched pair (until death) - the enclosed driveshaft rear-end has a shorter torque tube - there is a a very heavy cross-frame brace for the rear of the hydramatic - higher output generator - I am not certain if the shift indicator mounting holes on the steering column are the same as for the three-speed.
There were no special model numbers indicated in the vehicle serial number (on the left front door hinge pillar) for trucks with Hydra-Matics but the engine IDs for Hydra-Matics were something like F54M, F54MA, F54B (1/2, 3/4, and 1 tons built at Flint) or T54M, T54MA, T54MB (1/2, 3/4, and 1 tons built at Tonawanda).
Tim | | |
#87870 01/19/2002 5:22 AM | Joined: Jan 2002 Posts: 84 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 84 | I pulled the engine which had been dead a few years and traded it with the complete running gear to a friend who had a 54 that he wanted to re build with a old automatic setup. Only beacuse he knew I had one. thanks for the info and keep in touch...let me ask you do you have a grille that is in good condition for sale or can you find one? thank you,marlo | | |
