4 members (Donf, jay d, 46 Texaco, 1 invisible),
114
Mod | | | Forums66 Topics128,115 Posts1,056,633 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 43 | I have found a 1954 235 with the factory 4 speed man trans still on it from a P/U. It has the front center motor mount and shorty water pump as you would expect. I currently have a 1948 P/U with a 1951 216 & factory 4 speed man trans on it.
Can I swap out the 54 engine and trans combo with the current 216 engine trans in the truck fairly easy? It appears like a perfect match.
Keith
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I have not done a swap into a '54, but have swapped 216,235, and a 261 in AD models without any major problems.
Drew
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You won't be able to use the '54 bellhousing but you can put everything else on your existing bellhousing. | | | | | Joined: Aug 2012 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 43 | So the 54 bellhousing is shaped differently but has same bolt pattern? Can I use the 54 4 speed on the 51 Bellhousing as well?
Keith
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Aug 2012 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 43 | Thanks for this info/ it will save me a lot of time and aggravation when I go to swap them out. Can I pull the 216 engine & 4 speed Trans as one unit using a engine hoist. That is how I had pulle them as a kid when I worked on the cars of my era ?[ late 60 early 70 models]
Keith
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Only if you think you can clear the rear motor mount frame cross brace. The 4-speed transmission hangs a little low.
You cannot lift the engine more than about an inch without the clutch housing hitting the firewall.
