2 members (39Master85, 2Wheels), 105 guests, and 3 robots.
Topics128,196
Posts1,057,396
Members48,469
#878121 08/27/2012 2:28 PM
Guys,
I hope this is the right place to post this question.
Is there any trick to installing new vent window seals? I haven't purchased the seal kits yet. This is for my '59.
The vertical seal sections were the worst in condition and appeared to have rivets.
I'm just looking for a little guidance from someone who's been down this road.
Thanks!
Hey Jerry, I just did this. I bought the seals and rivets ,they give you 26 rivets.You can also buy the peen over tool as well. I riveted the vertical piece in [4 rivets]. The tech support will tell you the C shaped seal is riveted as well. The originals did not look as though they were riveted so I glued those seals in. I only removed 6 rivets per side the 4 for the vertical seal and the 2 on the division bar at the bottom of the vent window frame. Removing those 2 gives you enough room to remove the vent window assembly. The only problem I saw was the rivets I bought were too long for the vertical seal, so I shortened them up to work. I hope that helps. SEE YA! Mark
1955 Chevrolet 6100 Wrecker
More pix on Flickr
"A good mechanic doesn't know everything, but he can figure out anything". ~ --My DAD
1955 Chevrolet 6100 Wrecker Video
1955 Chevy 6100 Wrecker Update Video
Hey Jerry, this LINK may help as well. It's about doing door weather seals and such. They do it differently than I described. Good luck SEE YA! Mark
More pix on Flickr
Mark, you were a tremendous amount of help!
That's just what I needed.
Thanks, buddy!
Hey Jerry, You're welcome. I checked out your truck photos,VERY cool! SEE YA! Mark
More pix on Flickr
LOVE the wrecker you found, Mark! Sweet looking truck as is!
I was watching a show recently where a guy buys and flips autos. He bought an old car and liked its patina so much, he painted clear over it. It looked fantastic!
Hey Jerry, Thanks. I am leaving the exterior as is for now. I re-did everything else and am leaving the patina but no clear coat, at least not this year. I think I saw the show you mentioned, it's called Fast & Loud. I like that show. SEE YA! Mark
More pix on Flickr
